315
Pressing Escape in Edit mode
We use: 'BeforeAppointmentEdited' and 'AfterAppointmentEdited' events of the scheduler, to create and edit our Appointments.
Now when in the 'BeforeAppointmentEdited' event handler, i type a subject in the Appointment slot, then pressing Escape, the subject gets deleted and 'AfterAppointmentEdited' does not fire. I need to have a control over this. Is there a way by which i can listen to the EditCancelled event of the scheduler so that i can do something there.
Hemesh
  • 69832
    Suggested Answer
    I believe you can assign an Infragistics.Win.EditorWithText embeddable editor to the control's AppoitmentEditor property, and handle that editor's BeforeExitEditMode event. This will give you a notification right before the edit mode session ends; in the scenario you describe here, the 'ApplyChanges' property of the event arguments will return false.
