20
System.ComponentModel.Win32Exception: The operation completed successfully
   I'm calling a .Net 1.1 Infragistics calender windows control (32 bit) from an aspx page (old code) in Windows 2008 Server R2 (with WOW64) . This control was working on all operating systems including Windows 7 and when loaded in Windows 2008 Server R2 it throws up the exception given below.
I'm able to load the control sometimes, say 5% successful (only the first time when I load the application) and the remaining 95% it throws up the exception dialog box (sometimes it happens when I load the application for the first time too).
I've also attached the image of the dialog box that contains the following error meesage.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
   at System.Drawing.BufferedGraphicsContext.CreateCompatibleDIB(IntPtr hdc, IntPtr hpal, Int32 ulWidth, Int32 ulHeight, IntPtr& ppvBits)
   at System.Drawing.BufferedGraphicsContext.CreateBuffer(IntPtr src, Int32 offsetX, Int32 offsetY, Int32 width, Int32 height)
   at System.Drawing.BufferedGraphicsContext.AllocBuffer(Graphics targetGraphics, IntPtr targetDC, Rectangle targetRectangle)
   at System.Drawing.BufferedGraphicsContext.Allocate(IntPtr targetDC, Rectangle targetRectangle)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
CustomCalendar
    Assembly Version: 860.1.1.1
    Win32 Version: 860.1.1.1
    CodeBase: file:///C:/Program%20Files%20(x86)/ClientApplication/CustomCalendar.DLL
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Infragistics.Win.v4.3
    Assembly Version: 4.3.20043.27
    Win32 Version: 4.3.20043.27
    CodeBase: file:///C:/Program%20Files%20(x86)/ClientApplication/Infragistics.Win.v4.3.DLL
Infragistics.Shared.v4.3
    CodeBase: file:///C:/Program%20Files%20(x86)/ClientApplication/Infragistics.Shared.v4.3.DLL
WebApplication.API
    CodeBase: file:///C:/Program%20Files%20(x86)/ClientApplication/WebApplication.API.DLL
ApplicationUtilities
    CodeBase: file:///C:/Windows/assembly/GAC/ApplicationUtilities/860.1.1.1__5321fb4a87e940e2/ApplicationUtilities.dll
Accessibility
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Microsoft.mshtml
    Assembly Version: 7.0.3300.0
    Win32 Version: 7.0.3300.0
    CodeBase: file:///C:/Windows/assembly/GAC/Microsoft.mshtml/7.0.3300.0__b03f5f7f11d50a3a/Microsoft.mshtml.dll
Infragistics.Win.UltraWinSchedule.v4.3
    CodeBase: file:///C:/Program%20Files%20(x86)/ClientApplication/Infragistics.Win.UltraWinSchedule.v4.3.DLL
Infragistics.Win.Misc.v4.3
    CodeBase: file:///C:/Program%20Files%20(x86)/ClientApplication/Infragistics.Win.Misc.v4.3.DLL
System.Web.Services
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
System.Data
    CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
ajotsfos
ApplicationObject
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/ClientApplication/ApplicationObject.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
After some investigation I tried the following two techniques to solve this issue but couldn't fix it
Technique 1
According to this link http://nomagichere.blogspot.com/2008/03/systemcomponentmodelwin32exception-is.html
we should always dispose CreateGraphics() object everytime we call it. But i checked my code and we did dispose all the objects correctly. Even if its not disposed this error should also happen in Windows 7, but it only happens in Windows 2008 Server R2 (64 bit)
Technique 2
I thought that it could be related to the aspnet worker process (64 bit) trying to run the control (32 bit), so i tried the following command.
CSCRIPT %SYSTEMDRIVE%\Inetpub\AdminScripts\adsutil.vbs SET W3SVC/AppPools/Enable32bitAppOnWin64 1
 No change after running this command too.
This issue is blocking everything. Appreciate any ideas or fixes.
