560
Multicolumn Combo: Edit only one column
I am using a multicolumn combo with two columns: customer_id and customer_name. The combo supports autocompletion when the user types in some text. Is it possible to reduce the text to the customer_id while being in edit mode and show customer_id + customer_name after leaving edit mode?
Example: The form loads and shows '10300 test' as selected value. When the user enters the combo to search another customer, only the id '10300' should be shown in the combo.
I tried changing the display_value when entering and leaving edit mode but I cannot find any events that inform me about that.
Stefan
  • 469350
    Suggested Answer
    Hi Stefan,
    I'm not sure if this can be done, but one way you might try to go about it is by using a DataFilter. It seems like it would be pretty tricky, though, and again, I'm not sure if it's even possible.
