170
[UltraGrid] Dynamic creation of columns causing NullReferenceException on UltraGridColumn.Editor
Hi all,
I am working on a piece of code that should be able to display a set of data which is unknown on compile time: meaning I want to execute SQL statements, without knowing the model before execution.
Since the rows are in my case returned as object arrays (due to a generic transport model), I have to bind them at runtime.
This is the code I use for the moment:
List<UltraGridColumn> columns = new List<UltraGridColumn>();
int i = 0;
foreach (string entityField in actionTable.FieldDefinitions)
UltraGridColumn column = new UltraGridColumn(entityField, i++);
column.Header.VisiblePosition = i;
ultraGrid1.DisplayLayout.Bands[0].Columns.Add(column);
this.ultraGrid1.DataSource = actionTable.Result; // this is an object array.
In the InitializeLayout event I try the following:
UltraGridColumn column = this.ultraGrid1.DisplayLayout.Bands[0].Columns["fieldName1"];
if (column.Editor == null)
//execute some code
Then at the line with the "if (column.Editor == null)" a NullReferenceException is thrown. Does anyone have a clue why?
