235
How do I take off pencil icon from the grid rows.
How can i remove pencil icon form the grid rows on cell vaclue change.
i have some  requiremnet to change the grid cell value on enter mode. when i done this i am gettting the pencil symbol on the grid row staring. how can i revome this.
  Private Sub grdSample_AfterEnterEditMode(ByVal sender As Object, ByVal e As System.EventArgs) Handles grdDailyPricesFactors.AfterEnterEditMode
        DirectCast(DirectCast(grdSample.ActiveCell, Infragistics.Win.UltraWinGrid.UltraGridCell).EditorResolved, Infragistics.Win.EmbeddableEditorBase).Value = grdSample.ActiveCell.OriginalValue
      grdSample.UpdateData()
                    End Sub
 Even after giving the  grdSample.UpdateData() still i am getting the pencil symbol .  Please help me .
Subbu.
Subbu.
  • 918
    Suggested Answer
    If you want it off all the time them use this draw filter.
    Imports
    Infragistics.Win
    Imports
    Public
    Class
    clsRemovePencil
    Implements
    IUIElementDrawFilter
    Public Function GetPhasesToFilter(ByRef drawParams As
    _
    Infragistics.Win.UIElementDrawParams)
    As
    Infragistics.Win.DrawPhase _
    Implements
    Infragistics.Win.IUIElementDrawFilter.GetPhasesToFilter
    ' Drawing RowSelector Call DrawElement Before the Image is Drawn
    If TypeOf drawParams.Element Is
    _
    Infragistics.Win.UltraWinGrid.RowSelectorUIElement
    Then
    Return
    DrawPhase.BeforeDrawImage
    Else
    Return
    DrawPhase.None
    End
    If
    End
    Function
    Public Function DrawElement(ByVal drawPhase As
    _
    Infragistics.Win.DrawPhase,
    ByRef drawParams As
    _
    As Boolean Implements
    _
    Infragistics.Win.IUIElementDrawFilter.DrawElement
    ' If the image isn't drawn yet, and the UIElement is a RowSelector
    If drawPhase = drawPhase.BeforeDrawImage And TypeOf
    _
    drawParams.Element
    Is
    _
    Then
    ' Get a handle of the row that is being drawn
    Dim row As
    UltraGridRow = _
    CType(drawParams.Element.GetContext(Type.GetType("UltraGridRow"
    )), _
    UltraGridRow)
    'Debug.Print(row.Cells("txtVendorName").Value)
    ' If the row being draw is the active row
    If row.IsActiveRow
    Then
    ' Draw an arrow
    drawParams.DrawArrowIndicator(ScrollButton.Right, _
    drawParams.Element.Rect, _
    UIElementButtonState.Indeterminate)
    ' Return true, to stop any other image from being drawn
    Return
    True
    End
    If
    End
    If
    ' Else return false, to draw as normal or true to stop pencil
    'Return False
    Return
    True
    End
    Function
    End
    Class
  • 469350
    Suggested Answer
    Hi Subbu,
    My guess is that the UpdateData call cannot be honored while the cell is in the process of entering edit mode. If that's the case, then you might be able to work around it by calling this method using a BeginInvoke, rather than directly inside the event.
    If that does not work, then I don't see any way to do this just for this one situation. In other words, I don't see a way to turn off the pencil only when a cell enters edit mode. You can turn off the images in the RowSelectors entirely by setting RowSelectorAppearance.ImageAlpha to Transparent, of course.
