There are several bugs with Maximizing a form containing a UltraToolbarsManager. These (especially the second one) are causing further bugs in an application I am making. Attached is a simple project which I used to reproduce all the bugs listed below.1. Maximizing by dragging the form to the top of the screen does not work properly. It changes the form size correctly, but the maximize/restore button is disabled. Also, clicking on the title-bar causes the form to jump. Also, other forms are accessible to the top/bottom/sides of the 'maximized' form by clicking the mouse in those locations.2. After maximizing the form correctly (by double-clicking the titlebar or using the maximize button), dragging the titlebar down does not restore the form properly. It changes the size correctly, but the maximize/restore button is disabled. Also, the form still considers itself maximized in some sense, as double-clicking the title-bar restores it properly, instead of re-maximizing. Also, if the form loses focus (by clicking on the desktop or another application, for example), the form's border will not be re-drawn, as if it were maximized.
Hi mercuer,
I have created the following private case for you regarding this issue.
CAS-67263-C1BCWM
Sincerely,
Chris K
Developer Support Engineer
Infragistics, Inc.
www.infragistics.com/support
Hi!
I have exactly the same problems. is there any solution for this? i just downloaded the release 20011.1 but there is still the same behaviour.
please let me know if there is any workaround. many of our customers starting to use windows 7 and we are facing criticism because of this behaviour.
thx
I have forwarded this post to the Developer Support Manager and a DS engineer will be contacting you about this issue.
