140
FormDisplayStyle RoundedSizable change the form text font
Hi there,
here are a few question about using ultratoolbarsmanager on my forms:
1/ when using an ultratoolbarsmanager on a form and setting the formDisplayStyle to RoundedSizable (not showing the ribbon), my form header text displays as Bold .. (see attachment)
I was wondering if there was any chance to change this default behaviour and restore an "unbold" text instead ? I've looked into the appstylist isl files but didn't see any prop'.. I also checked and tried lots of appearances properties on the ultratoolbarsmanager but didn't find any way to ignore this bold font.
2/ when deploying my app to vista machines, it's seems the form border style (still using the ultratoolbarsmanager whith formdisplaystyle set to Roundedsizable or showing the ribbon) has a stange look ..  a little crap, in fact: the form text doesn't render very well (kind of a glow effect around the form text) and the Maximize/minimize/restore button on the right don't show all the time .. I need to double click the form header (causing a resize) to display them correctly, as if there were not drawing properly on the first paint .. is this a known problem ? Note that there is no code on my form that act on the Paint event or so on .. just a simple form with a ultratoolbarsmanager showing the ribbon..
Any help would be greatly appreciated !
Happy new year to the whole Infragistics team
François
  • 44743
    1. This is correct functionality and this is how it works in Microsoft Office 2007. You can get around this by setting the Ribbon.Caption value to a value with formatting which doesn't use bold. I think you can change this in AppStyling by setting the Font's Bold value to False on the RibbonCaptionArea role's Active role state.
    2. This sounds like a bug which had been addressed in the past. Try upgrading to the latest SR to see if it fixes this issue.
