I have a grid whose datasource is set to a bindingsource whose datasource is set to a c# business object that has some properties, collections, methods, etc.
I set my MaxBandDepth to 1 so that the children don't show up.
I set the datasource of the bindingsource to the single object record that has some of its properties populated.
I set the datasource of grid to the BindingSource inside a button event.
I do not perform any action inside _AfterRowActivate event.
All i see is a grid with ONLY COLUMN HEADINGS and no rows showing up for any columns.
When i do the binding process with another much more complicated business object, then the rows show up properly.
Please help what might be wrong.
Scott.
Figured out the solution. I reset the datasource property of the grid to NULL by using the statement as follows:
mygrid.Datasource = null;
The grid now shows the column values happily.
FYI,
When I debug the code, before assigning datasource to the grid, I saw the grid already has some empty columns as its datasource. Do i need to clear these? If yes, how? Please specify.
The object to which the bindingsource is bound to has some collections which have count = 0. Just wanted to share this info.
Most of the column values are 'NULL' however a couple of them are not null. I am sure, these columns too are not shown any value. The grid is empty and has only column names.
FYI, when I debug Datasource for the grid, it does show up the rows count and other information.
