144
Excess CPU usage by UltraGrid
I have a UltraGrid to which i continously insert rows at the rate of 15rows/sec,  The grid has 50 rows and 14 columns, there is a datatable which am assigning to the datasource propery of the Grid and every time i create a new datarow and insert it to the datatable and then move it to the required postion in the grid.
Code is as follows
//m_dtMessagesView is my datatable
DataRow row = m_dtMessagesView.NewRow();
// here is the code to assign values to each column of new datarow i.e. row
m_dtMessagesView.Rows.InsertAt(row, 0);
int listIndex = m_dtMessagesView.Rows.IndexOf(row);
UltraGridRow ultraRow =
this.Rows.GetRowWithListIndex(listIndex);
if (this.DisplayLayout.Bands[0].Columns[4].SortIndicator == SortIndicator.Descending)
this.Rows.Move(ultraRow, 0);
This causes excessive CPU usage of 50% at the rate of insertion mentioned above.
I have also used BeginUpdate and EndUpdate as told Infragistic performance Guide. I tried inserting rows without any values to the column, which also had the same CPU usage.
 Thanks in advance,
Vinay
