I have a grid where certain cells have had there appearance object modified so thier forecolor is different from all the other cells. When the row becomes selected, those cells with custom forecolor settings are displayed as having default colors. Is there a setting that can be changed so that the selected row uses the appearance of the cell?
In addition to the Appearance property of the cell, there is also a SelectedAppearance. So you probably want to just set both to the same appearance. That way, when the cell is selected, it will appear the same as when it is not selected.
You might try by changing the Selected Row Appearance to that of the cell by
UltraWingridDesigned-->Apperance Browser-->Row Appearances-->Selected Row
Here you can set the BackColor ,ForeColor etc same as the cell or transparent if you dont want the selected row to be highlighted.
Or you can set it explicity in code.
-K
