155
UltraDesktop Alert Memory Exception
    I have recently started seeing an exception being thrown from our application within the development environment (VS2008 SP1) when using the alerts. The application displays 2 alerts on start-up, 1 from 2 different UltraDeskTopAlert controls on the form. The 1st displays OK and the second then throws the error stack below.
The only change I can think of is that recetnly we have increased the workstation (XP) memory to 4GB and launched XP using the /3GB switch. Would this affect the controls in any way?
We are using version 8.3.20083.2021.
The exception is thrown from the routine:
Dim ultraAlert As
Infragistics.Win.Misc.UltraDesktopAlertShowWindowInfo = alertBase.UltraAlertObject
alertBase.SetUltraAlertProviderForMsg(MDIAlertsWarnings)
If ultraAlert IsNot Nothing AndAlso Not MDIAlertsWarnings.IsOpen(ultraAlert.Key)
Then
If _setalertDlgWarning Is Nothing
Then
_setalertDlgWarning =
New SetAlertDelegateDefWarning(AddressOf
SetAlertDelegateWarning)
End
If
Me.Invoke(_setalertDlgWarning, New Object
() {ultraAlert})
End
If
   at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
   at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
   at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks)
   at System.Delegate.DynamicInvokeImpl(Object[] args)
   at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
   at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
   at System.Threading.ExecutionContext.runTryCode(Object userData)
   at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
   at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
   at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
   at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.Run(Form mainForm)
   at CMS.CMSControl.main(String[] args) in W:\EXETERXP14\dev\Source\CMS.NET\ContractManagementSystem\clsMCMControl.vb:line 509
 Inner Trace:
Not enough storage is available to process this command
   at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous)
   at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args)
   at CMS.CMSMdi.DisplayDeskTopAlertWarning(AlertDefWarningBase alertBase) in frmCmsMdi.vb:line 1917
Thanks for any help or fix suggestions.
  • 155
    By the way, the only way to clear the problem is to re-start VS2008.
