Hello all,
I am developing an application's interface with the requirement that I use Infragistics controls throughout. I am using the 2009.2 release.
I have a need to provide an interface for categorized "name-value" data of mixed types and I thought I could use some way to make either WinTree (as shown in a sample) or WinGrid behave like the .NET PropertyGrid control.
What I need is a way to add the "name-value" items on a row basis, with the appropriate editor for its data-type, which are not that many, simple numeric edit, masked edit, check-box and combo-box. I don't need the reflection support provided by some solutions. What I need is an example of a set of these controls working in WinTree, displaying their editors correctly and responding to change events.
An example interface for two mixed data items:
Name | Value
[-] Category 1
Number | 1.4
Boolean | [x]
List | value3 [\/]
[-] Category 2
Number | 2.0
Boolean | [ ]
List | value2 [\/]
I have read the various attempts in relevant posts, and tried their suggestions, some of which I could not even get to work. The editors I assigned would not appear for the values...
Can anyone help with a sample with the above editors that actually works ?
Thanks in advance
nickpap
nickpap said:What I need is a way to add the "name-value" items on a row basis, with the appropriate editor for its data-type, which are not that many, simple numeric edit, masked edit, check-box and combo-box
nickpap said:The editors I assigned would not appear for the values
I think this can be achieved via hierarchical datasource organized as follows:
1. One main datatable with the categories;
2. One sub table for the numbers, one for the Booleans and one for the list (and onther one for the values in the list)
Please check the attached sample.
Let me know if you still need any help.
Stefaniya
