45
Error encountered while loading from stream
I am using the Ultra Toolbars Manager 7.1 in VS 2005
I have an application that has a ribbon with all my tabs, buttons, pop-up galleries, etc... and I have used the Load/Save Configuration option on the control to save the ribbon into an XML file.
I have a new application I am working on and I don't want to have to recreate the ribbon so I tried to use the Load/Save Configuration option to load the XML file from the first application. That is when I get an error that states "Error encountered while loading from stream".
I can manually open the XML file and view the contents with no problem and my first application that I designed the ribbon in works just fine.
I have attached the XML file to this post. Can anyone shed any light on what my problem might be or a direction on things I should try to resolve this.
Thank you,
Nathan
toolbarbackup.zip
