I'm trying to change the appearance of the highlighted section of a cardview grid. Within the UltraWinGrid Designer, I have tried modifying the BackColor, BackColor2, and ForeColor values under "Card Appearances -> Card Caption", but the caption appearance does not change.
Any ideas?
Thanks!
That seemed to do the trick, thank you.
My guess is that the default appearance is using Windows Themes, which will override any other settings. Try setting the ThemedElementAlpha on the caption appearance to Transparent to turn off themes and then the BackColor should work.
