635
Difference between grouping via drag-drop vs programmatically
I'm seeing a difference in behavior and I was hoping someone could help me out. If I drag a column into the group area and then drag it out, the column re-appears in its original location.
If I instead programatically group that same column doing this:
Grid.DisplayLayout.Bands[0].Columns[itemColumnKey].Hidden = itemHiddenValue;
Grid.DisplayLayout.Bands[0].Columns[itemColumnKey].Header.VisiblePosition = itemPosition;
 Grid.DisplayLayout.Bands[0].SortedColumns.Add(itemColumnKey, true, true);
and then drag it out of the group area, the column disappears completely.
I would like the column to re-appear in its previous location the same as if it were grouped via drag-drop. Any help would be appreciated.
