100
Multiple UltraGrid(s) on form AND DrawElement(), GetPhasesToFilder
I have used code from one of your WinForm UltraGrid examples, which uses DrawElement and GetPhasesToFilter functions.
However, I have a form using the UltraTabControl. Each tab contains it's own UltraGrid. In your code for DrawFilter, you reference the specific UltraGrid on the form, ie: UltraGrid1.
I need distinct DrawElement and GetPhasesToFilter functions.
How to I accomplish this.
Michael Jackson
  • 5118
    The filters are still applied to a specific grid and not every grid that is present on the form.  So for the filter to be applied to MyGrid, you need to set MyGrid.DrawFilter = New MyFilter(); and the DrawFilter will only be applied to the specific Instance of MyGrid that I set this property.  If I have another instance on the form it will not be applied to other one as I did not set the DrawFilter property of the other instance.
