I have several saved layouts from version 7.3. When I moved up to v8.3 the layouts will not load. Is there a way to convert saved layouts to a later version without having to recreate them?
You should not have to do anything, the layouts should be backward compatible. What exactly do you mean when you say "the layouts will not load"? Are you getting an error?
