Hi, I have a problem with scrollbar on UltraTree control (also under 9.1v of Infragistics)
When I open a dialog form with tree to show available nodes i want to show currently select node in my application.
To achieve selection i use this piece of code
m_objTree.SelectedNodes.Clear();
node.BringIntoView();
node.Selected = true;
m_objTree.ActiveNode = node;
Opening this modal form causing strange tree look ( look at Attachment 1), the scrollbar does not work at the beggining... I cannot see the top of the tree/root. The scrollbar seems to come into effect when I move it. (Attachment 2)
Any ideas?
Thanks in advance.
Regards.
[Attachment 1]
[Attachment 2]
Yes I am having the same issue. I'm using v9.2.2042. Very wierd. I'm not even doing any special selecting, etc. Although in my case I'm using the OutlookExpress viewstyle with multiple columns.
