30
UltraDropDown problem with auto expansion
I have an ultraDropDown being used to display drop down lists for a column on my ultra grid, but the first column wont expand so that you can see the whole value, I have tried turning on autosize and even manually setting the width of the ultra drop down to no avail.
Code:
Dim creatorUltraDropDown As New UltraDropDown
creatorUltraDropDown.DataSource = ObjectDataSet.Tables("BA")
creatorUltraDropDown.Width = 1000
creatorUltraDropDown.ValueMember = "BA_NAME"
creatorUltraDropDown.DisplayLayout.Bands(0).Columns(0).AutoSizeMode = ColumnAutoSizeMode.AllRowsInBand
creatorUltraDropDown.DisplayLayout.BorderStyle = UIElementBorderStyle.None
creatorUltraDropDown.DisplayLayout.Bands(0).ColHeadersVisible = False
'Hide all columns
For Each column As UltraGridColumn In creatorUltraDropDown.DisplayLayout.Bands(0).Columns
    column.Hidden = True
Next
creatorUltraDropDown.DisplayLayout.Bands(0).Columns("BA_NAME").Hidden = False
creatorUltraDropDown.DisplayLayout.Bands(0).Columns("code_value").Hidden = False
creatorUltraDropDown.DisplayLayout.Bands(0).Columns("BA_NAME").Header.VisiblePosition = 0
creatorUltraDropDown.DisplayLayout.Bands(0).Columns("code_value").Header.VisiblePosition = 1
.DisplayLayout.Bands(0).Columns("ID").ValueList = creatorUltraDropDown
.DisplayLayout.Bands(0).Columns("ID").Style = ColumnStyle.DropDownList
Cheers,
Ian
  • 469350
    Suggested Answer
    Hi Ian,
    The size of the dropdown probably is not the problem. My guess is the you need to autosize the columns inside the dropdown so that they show their entire contents.
