45
xls file from Excel Mobile
When I offer an xls file from Excel Mobile (6.1) to the Workbook.Load method (Infragistics.Excel 8.2) I get an ArgumentException: "An item with the same key has already been added.". It's ok when I read an xls file of exactly the same content from Excel 2007 (Win XP) . Did anyone run into this issue as well? Can you tell if this issue was fixed in later Infragistics versions?
  • 12480
    Are you able to provide an excel document that reproduces the error? I will test the file with the most up to date version and let you know the results.
    Does this issue occur when loading any xls file created in Excel Mobile, or is it only a certain file?
