710
UltraCalendarCombo in ultragrid
I am using EditControl in gridcell to embed the ultraCalendarCombo. I have few issues:
1. As default, the date is shown as follow ex: 1/14/10. Instead, I would like to show us 14 Jan, 2010. Is it possible as a default setting?
2. Related to number 1 above, it the cell value is 14 Jan, 2010, it seems that the ultraCalendarCombo control is not able to set the date. Means the respective day doesn't get highlight.
Can you advise if they are solutions for the above please?
  • 469350
    Suggested Answer
    The cell is probably just displaying the ToString of the Value in the cell. You might be ablet o get what you want be setting the Format property on the cell. The format you specify is passed into the ToString method on the cell's Value. So I'm not sure if the DateTime data type supports a format what will show you the text as you have it here, but I think it probably does. Note that this will only apply to cells that are not in edit mode.
    I don't understand what you mean by this.
