1440
Red X in UltraWinGrid
Every now and then and with no repeatable pattern, I get a red X displayed during the loading of a UltraWinGrid.  The code in using is below:
sqlCn.Open()
sqlReader = sqlCmd.ExecuteReader()
If sqlReader.HasRows Then
tabCoInfo.Load(sqlReader)
ugCompanies.DataSource = tabCoInfo
m_Firsttime_Flag = True
End If
sqlCn.Close()
Below is the content of the stack trace when this happened.
System.NullReferenceException: Object reference not set to an instance of an object.
   at Infragistics.Win.UIElement.DrawChildElements(UIElementDrawParams& drawParams)
   at Infragistics.Win.UIElement.DrawElement(UIElementDrawParams& defaultDrawParams)
   at Infragistics.Win.UIElement.DrawHelper(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Boolean clipText, Boolean forceDrawAsFocused, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   at Infragistics.Win.UltraWinGrid.UltraGridUIElement.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   at Infragistics.Win.UltraControlBase.OnPaint(PaintEventArgs pe)
   at Infragistics.Win.UltraWinGrid.UltraGrid.OnPaint(PaintEventArgs pe)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4200 (NetFxQFE.050727-4200)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Microsoft.VisualStudio.HostingProcess.Utilities
    Assembly Version: 9.0.0.0
    Win32 Version: 9.0.30729.1
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualStudio.HostingProcess.Utilities/9.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.HostingProcess.Utilities.dll
    Win32 Version: 2.0.50727.4016 (NetFxQFE.050727-4000)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Microsoft.VisualStudio.HostingProcess.Utilities.Sync
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualStudio.HostingProcess.Utilities.Sync/9.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.HostingProcess.Utilities.Sync.dll
Microsoft.VisualStudio.Debugger.Runtime
    Win32 Version: 9.0.21022.8
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualStudio.Debugger.Runtime/9.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.Debugger.Runtime.dll
vshost
    CodeBase: file:///C:/Users/Clay/Documents/Visual%20Studio%202008/Projects/LoadContacts/bin/Debug/LoadContacts.vshost.exe
Infragistics2.Shared.v9.1
    Assembly Version: 9.1.20091.2077
    Win32 Version: 9.1.20091.2077
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Shared.v9.1/9.1.20091.2077__7dd5c3163f2cd0cb/Infragistics2.Shared.v9.1.dll
Infragistics2.Win.Misc.v9.1
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.Misc.v9.1/9.1.20091.2077__7dd5c3163f2cd0cb/Infragistics2.Win.Misc.v9.1.dll
Infragistics2.Win.UltraWinDataSource.v9.1
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinDataSource.v9.1/9.1.20091.2077__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinDataSource.v9.1.dll
Infragistics2.Win.UltraWinGrid.v9.1
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinGrid.v9.1/9.1.20091.2077__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinGrid.v9.1.dll
Infragistics2.Win.v9.1
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.v9.1/9.1.20091.2077__7dd5c3163f2cd0cb/Infragistics2.Win.v9.1.dll
System.Data
    CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Core
    Assembly Version: 3.5.0.0
    Win32 Version: 3.5.30729.1 built by: SP
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
System.Xml.Linq
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml.Linq/3.5.0.0__b77a5c561934e089/System.Xml.Linq.dll
System.Data.DataSetExtensions
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Data.DataSetExtensions/3.5.0.0__b77a5c561934e089/System.Data.DataSetExtensions.dll
Microsoft.VisualBasic
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.4016 (NetFxQFE.050727-4000)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
LoadContacts
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Users/Clay/Documents/Visual%20Studio%202008/Projects/LoadContacts/bin/Debug/LoadContacts.EXE
System.Runtime.Remoting
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
Microsoft.Office.Interop.Outlook
    Assembly Version: 12.0.0.0
    Win32 Version: 12.0.4518.1014
    CodeBase: file:///C:/Windows/assembly/GAC/Microsoft.Office.Interop.Outlook/12.0.0.0__71e9bce111e9429c/Microsoft.Office.Interop.Outlook.dll
Interop.Redemption
    Assembly Version: 4.6.0.0
    Win32 Version: 4.6.0.0
    CodeBase: file:///C:/Users/Clay/Documents/Visual%20Studio%202008/Projects/LoadContacts/bin/Debug/Interop.Redemption.DLL
Accessibility
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Transactions
    CodeBase: file:///C:/Windows/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
    CodeBase: file:///C:/Windows/assembly/GAC_32/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
CustomMarshalers
    CodeBase: file:///C:/Windows/assembly/GAC_32/CustomMarshalers/2.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Two questions:
1)  How do I prevent this from happening?
2)  If it does happen, how can I display something other than the red x?
