120
Exception on using TearOffMenu
I added a Infragistics popup menu to the UltraWinGrid, and selected the "allow tearaway". Runs, looks great. Start to tear away, and it gives the below exception: Any ideas what the problem is?
Unhandled Exception
Unhandled Exception:
Object reference not set to an instance of an object.
System.NullReferenceException
Stack Trace:
   at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.OnDragTearawayMove()
   at Infragistics.Win.UltraWinToolbars.PopupMenuTearawayStripUIElement.OnMouseMove(MouseEventArgs e)
   at Infragistics.Win.ControlUIElementBase.ProcessMouseMoveHelper(Object sender, MouseEventArgs e)
   at Infragistics.Win.ControlUIElementBase.ProcessMouseMove(Object sender, MouseEventArgs e)
   at Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e)
   at Infragistics.Win.UltraControlBase.OnMouseMove(MouseEventArgs e)
   at System.Windows.Forms.Control.WmMouseMove(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
   at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
   at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.Run(Form mainForm)
   at Bombardier.Orbiflo.Windows.AbstractApplication.Run()
   at Bombardier.Orbiflo.Windows.Forms.ShellApplication.Main()
OK
