Is there and control I can use when it is exporting to not export the child bands?
Thanks for the idea, although I figured another way out to accomplish this.
Since my information was coming from a DSO I saved it as a binary to a memory stream and reset the child bands on that DSO and then reset the grid to use this DSO when I wanted it to. Once it was done it would reset it back to the original DSO.
What you should do is handle the BeginExport event on the UltraGridExcelExporter. The event passes in a Layout which is a clone of the grid's DisplayLayout. Since it's a clone, you can modify it any way you like and it will affect the export without affecting the on-screen grid. So the easiest thing for you to do is to simply set ViewStyle to SingleBand on this layout.
