When a grid is grouped by some column and exported to excel using UltraGridExcelExporter, how to show headers only once and also how to exclude empty rows?
Thanks,Rajesh.
I do not have any other settings on the grid, It is may be because of the older version.
Thanks,Rajesh
Hi Rajash,
I didn't get that extra space when I tested this. So maybe this is a bug in the version of the controls that you are using. You should try getting the latest service release and see if that helps.
If that does not help, then there must be some other setting you are using that I am not, or else something in your code that is doing this.
Attached is excel exported from the grid.
I do not know why Rows #5, #10, #12.. appear as empty rows.
Hi Rajesh,
I'm still not sure what empty rows you are referring to. I tested this out using the SummaryDisplayArea settings you listed here with a grouped grid and I don't see any empty rows in Excel when I export the grid, except for the rows in between the bands.
Maybe you could post a screen shot or an Excel file that shows what you mean.
I am using the below property for the summary display area
gridToFormat.Grid.DisplayLayout.Override.SummaryDisplayArea = SummaryDisplayAreas.TopFixed
Or SummaryDisplayAreas.GroupByRowsFooter Or SummaryDisplayAreas.InGroupByRows
So, when I export the grid to excel which is grouped by some x column, I see an empty row after each header.
