220
Index was outside the bounds of the array error
Hi. I'm getting an error when attempting to populate a Dataset. The details are below.
For reference, I have bound the UG to the Dataset, and am populating the dataset through a backgroundworker using a datareader using the following code:
Try
            myConn.Open()
            myReader = myCommand.ExecuteReader
            Do While myReader.Read
                If Me.BackgroundWorker1.CancellationPending Then
                    'Cancel the execution of this query.
                    Debug.WriteLine("BGW Cancelled: " & Now.ToString)
                    Exit Sub
                Else
                    'No Cancellation pending, keep filling the DataSet.
                    Dim myRow As System.Data.DataRow = Me.DS_Tags_Tags1.Tables(0).NewRow
                    For i As Integer = 0 To (myReader.FieldCount - 1)
                        myRow(myReader.GetName(i).ToString) = myReader(i)
                    Next
                    DS_Tags_Tags1.Tables(0).Rows.Add(myRow)
                End If
            Loop
        Catch ex As Exception
            MessageBox.Show("Unable to retrieve tag details from the DataBase" & vbCrLf & vbCrLf & "Details:" & vbCrLf & ex.Message, AppName & " - Unable to Retrieve Tags", MessageBoxButtons.OK, MessageBoxIcon.Error)
        Finally
            If myConn IsNot Nothing AndAlso myConn.State = ConnectionState.Open Then
                myConn.Close()
            End If
            myCommand = Nothing
            myReader = Nothing
            Debug.WriteLine("DataSet Fill Ended: " & Now.ToString)
        End Try
I upgraded to the latest Infragistics hotfix the other week (1043 I believe), in order to resolve a similar error when refreshing the Dataset on the Ultracombos.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IndexOutOfRangeException: Index was outside the bounds of the array.
   at Infragistics.Shared.SparseArray.EnsureScrollCountCalculatedHelper(NodeExtended n)
   at Infragistics.Shared.SparseArray.EnsureScrollCountCalculated()
   at Infragistics.Shared.SparseArray.GetVisibleIndexOf(ISparseArrayMultiItem item, Boolean ignoreItemHiddenState)
   at Infragistics.Shared.SparseArray.GetItemAtVisibleIndexOffset(ISparseArrayMultiItem startItem, Int32 offset, ICreateItemCallback createItemCallback)
   at Infragistics.Win.UltraWinGrid.ScrollCountManagerSparseArray.GetItemAtVisibleIndexOffset(UltraGridRow startRow, Int32 offset)
   at Infragistics.Win.UltraWinGrid.RowsCollection.GetRowAtVisibleIndexOffset(UltraGridRow startAtRow, Int32 visibleIndexOffset, IncludeRowTypes includeRowTypes)
   at Infragistics.Win.UltraWinGrid.RowsCollection.GetNextVisibleRow(UltraGridRow row, IncludeRowTypes includeRowTypes)
   at Infragistics.Win.UltraWinGrid.RowsCollection.GetNextVisibleRow(UltraGridRow row)
   at Infragistics.Win.UltraWinGrid.ViewStyleBase.AddSiblingRows(VisibleRowFetchRowContext& context, VisibleRow parentVisibleRow, UltraGridRow firstSibling)
   at Infragistics.Win.UltraWinGrid.ViewStyleBase.RecreateRowList(RowScrollRegion rsr)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.GetMaxScrollPosition(Boolean scrollToFill)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.EnsureScrollRegionFilled(Boolean calledFromRegenerateVisibleRows)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.RegenerateVisibleRows(Boolean resetScrollInfo)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.WillScrollbarBeShown(ScrollbarVisibility assumeColScrollbarsVisible)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.PositionScrollbar(Boolean resetScrollInfo)
   at Infragistics.Win.UltraWinGrid.ScrollRegionBase.SetOriginAndExtent(Int32 origin, Int32 extent)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.SetOriginAndExtent(Int32 origin, Int32 extent)
   at Infragistics.Win.UltraWinGrid.DataAreaUIElement.ResizeRowScrollRegions()
   at Infragistics.Win.UltraWinGrid.DataAreaUIElement.PositionChildElements()
   at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
   at Infragistics.Win.UltraWinGrid.DataAreaUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
   at Infragistics.Win.UltraWinGrid.DataAreaUIElement.set_Rect(Rectangle value)
   at Infragistics.Win.UltraWinGrid.UltraGridUIElement.PositionChildElements()
   at Infragistics.Win.UltraWinGrid.UltraGridUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
   at Infragistics.Win.UIElement.DrawHelper(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Boolean clipText, Boolean forceDrawAsFocused, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.UIElement.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Boolean forceDrawAsFocused, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   at Infragistics.Win.UltraWinGrid.UltraGridUIElement.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   at Infragistics.Win.UltraControlBase.OnPaint(PaintEventArgs pe)
   at Infragistics.Win.UltraWinGrid.UltraGrid.OnPaint(PaintEventArgs pe)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
    CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Microsoft.VisualStudio.HostingProcess.Utilities
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.42
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualStudio.HostingProcess.Utilities/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.HostingProcess.Utilities.dll
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Microsoft.VisualStudio.HostingProcess.Utilities.Sync
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualStudio.HostingProcess.Utilities.Sync/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.HostingProcess.Utilities.Sync.dll
vshost
    CodeBase: file:///C:/SVN/Orbit/Orbit/bin/Debug/Orbit.vshost.exe
ADODB
    Assembly Version: 7.0.3300.0
    Win32 Version: 7.10.6030
    CodeBase: file:///C:/WINDOWS/assembly/GAC/ADODB/7.0.3300.0__b03f5f7f11d50a3a/ADODB.dll
System.Data
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Deployment
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Deployment/2.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll
System.Design
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
System.Runtime.Serialization.Formatters.Soap
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Serialization.Formatters.Soap/2.0.0.0__b03f5f7f11d50a3a/System.Runtime.Serialization.Formatters.Soap.dll
System.Web
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System.Xml
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Infragistics2.Excel.v7.3
    Assembly Version: 7.3.20073.1043
    Win32 Version: 7.3.20073.1043
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Excel.v7.3/7.3.20073.1043__7dd5c3163f2cd0cb/Infragistics2.Excel.v7.3.dll
Infragistics2.Win.UltraWinDataSource.v7.3
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinDataSource.v7.3/7.3.20073.1043__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinDataSource.v7.3.dll
Infragistics2.Win.UltraWinGrid.ExcelExport.v7.3
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinGrid.ExcelExport.v7.3/7.3.20073.1043__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinGrid.ExcelExport.v7.3.dll
Infragistics2.Win.UltraWinTabbedMdi.v7.3
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinTabbedMdi.v7.3/7.3.20073.1043__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinTabbedMdi.v7.3.dll
Infragistics2.Shared.v7.3
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Shared.v7.3/7.3.20073.1043__7dd5c3163f2cd0cb/Infragistics2.Shared.v7.3.dll
Infragistics2.Win.Misc.v7.3
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.Misc.v7.3/7.3.20073.1043__7dd5c3163f2cd0cb/Infragistics2.Win.Misc.v7.3.dll
Infragistics2.Win.UltraWinEditors.v7.3
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinEditors.v7.3/7.3.20073.1043__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinEditors.v7.3.dll
Infragistics2.Win.UltraWinExplorerBar.v7.3
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinExplorerBar.v7.3/7.3.20073.1043__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinExplorerBar.v7.3.dll
Infragistics2.Win.UltraWinGrid.v7.3
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinGrid.v7.3/7.3.20073.1043__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinGrid.v7.3.dll
Infragistics2.Win.UltraWinStatusBar.v7.3
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinStatusBar.v7.3/7.3.20073.1043__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinStatusBar.v7.3.dll
Infragistics2.Win.UltraWinTabControl.v7.3
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinTabControl.v7.3/7.3.20073.1043__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinTabControl.v7.3.dll
Infragistics2.Win.UltraWinToolbars.v7.3
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinToolbars.v7.3/7.3.20073.1043__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinToolbars.v7.3.dll
Infragistics2.Win.v7.3
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.v7.3/7.3.20073.1043__7dd5c3163f2cd0cb/Infragistics2.Win.v7.3.dll
Microsoft.VisualBasic
    Win32 Version: 8.0.50727.1433 (REDBITS.050727-1400)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
Orbit
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/SVN/Orbit/Orbit/bin/Debug/Orbit.EXE
System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
Infragistics.License
    Assembly Version: 1.0.5005.10
    Win32 Version: 1.0.5005.10
    CodeBase: file:///C:/WINDOWS/assembly/GAC/Infragistics.License/1.0.5005.10__7dd5c3163f2cd0cb/Infragistics.License.dll
System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Accessibility
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Transactions
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
