If we call the Reset method on this control is blows up with object ref not set exception, its caused by the FireCalendarInfoChangedEventHelper method. I haven't had time to look in to it further than that and have a workaround for what I need to do, just curious as to what could be causing this - its entirely possible the control is not set up quite right.
This is on v7.3 under VS2008 & .NET 3.5, the form it is on was originally written under VS2005, .NET 2.0 and netadvantage 6.3, I think this problem has come up during conversion somewhere.
Are there any common causes of this I can look at ?
Hello Mark_C,I was able to reproduce your scenario. Based on our the product life cycle at http://ko.infragistics.com/support/service-releases.aspx#ProductLifecycle v7.3 is no longer supported. I would suggest you to use at least v8.1, because this issue was fixed there first.
You can also use the v11.1 trial of NetAdvantage components.
Please note, we are making efforts to ensure all posts are addressed by an Infragistics expert. We believe that the other community members could benefit from this thread as well.
Please do not hesitate to contact us if you need any additional assistance.
