Is this a known bug with WinGrid in CardView? I have a WinGrid with CardView enabled which I load with new data depending on some other control (Grid.DataSource = null followed by Grid.DataSource = DataTable). Within Grid.InitializeLayout() I'm setting grid width to the visible area of the parent control (that value remains static) -Grid.DisplayLayout.Bands[0].CardSettings.Width = parentcontrol.Width
Every time new data is loaded into the grid and Grid.InitializeLayout() is called the card area width grows a little more than the time before (even though the width value is the same)...Basically after Initializelayout is called twice card area extends beyond the visible area by a significant margin. Is there any workaround for this issue?? It seems setting grid datasource = null also resets CardSettings.Width to zero...
I am not aware of any issues like this. My first suggestion would be to get the latest service release and see if that helps:
If it does not, we will need to see a small sample project demonstrating this behavior so we can get it corrected.
