995
An item with the same key has already been added? get_ScrollCountInternal bug?
I have been seeing this error quite often in the ultrawingrid. I read an earlier post about a possible bug but I have the latest code and still see the problem. Below is the full exception info but here is how the application works.
A separate class builds a dataset and adds rows as a timer ticks. However, this happens before the timer adds the rows on the initial load of data. I have a check to make sure the dataset is fully created and the data is loaded before binding the dataset to the grid. I have also seen the error "Index was outside the bounds of the array" coming from the same routine get_ScrollCountInternal(). Here are both items:
System.ArgumentException: An item with the same key has already been added.
   at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource)
   at System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)
   at Infragistics.Win.UltraWinGrid.UltraGridRow.get_ScrollCountInternal()
   at Infragistics.Win.UltraWinGrid.UltraGridRow.Infragistics.Shared.ISparseArrayMultiItem.get_ScrollCount()
   at Infragistics.Shared.SparseArray.EnsureScrollCountCalculatedHelper(NodeExtended n)
   at Infragistics.Shared.SparseArray.EnsureScrollCountCalculated()
   at Infragistics.Shared.SparseArray.GetVisibleCount()
   at Infragistics.Shared.SparseArray.GetItemAtVisibleIndex(Int32 visibleIndex, ICreateItemCallback createItemCallback)
   at Infragistics.Win.UltraWinGrid.ScrollCountManagerSparseArray.GetItemAtVisibleIndex(Int32 visibleIndex)
   at Infragistics.Win.UltraWinGrid.RowsCollection.GetRowAtVisibleIndex(Int32 visibleIndex, Boolean includeSpecialRows)
   at Infragistics.Win.UltraWinGrid.RowsCollection.GetFirstVisibleRow()
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.get_FirstRow()
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.GetMaxScrollPosition(Boolean scrollToFill)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.EnsureScrollRegionFilled(Boolean calledFromRegenerateVisibleRows)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.RegenerateVisibleRows(Boolean resetScrollInfo)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.WillScrollbarBeShown(ScrollbarVisibility assumeColScrollbarsVisible)
   at Infragistics.Win.UltraWinGrid.ViewStyleBase.FitColumnsToWidth()
   at Infragistics.Win.UltraWinGrid.BandsCollection.CalculateBandMetrics(Int32 pass)
   at Infragistics.Win.UltraWinGrid.BandsCollection.CalculateBandMetrics()
   at Infragistics.Win.UltraWinGrid.ColScrollRegionsCollection.InitializeMetricsHelper()
   at Infragistics.Win.UltraWinGrid.ColScrollRegionsCollection.InitializeMetrics()
   at Infragistics.Win.UltraWinGrid.DataAreaUIElement.PositionChildElements()
   at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
   at Infragistics.Win.UltraWinGrid.DataAreaUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
   at Infragistics.Win.UltraWinGrid.DataAreaUIElement.set_Rect(Rectangle value)
   at Infragistics.Win.UltraWinGrid.UltraGridUIElement.PositionChildElements()
   at Infragistics.Win.UltraWinGrid.UltraGridUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
   at Infragistics.Win.UIElement.VerifyChildElements(Boolean recursive)
   at Infragistics.Win.UltraWinGrid.UltraGridUIElement.InternalInitializeRect(Boolean verify)
   at Infragistics.Win.UltraWinGrid.UltraGridLayout.GetUIElement(Boolean verify, Boolean forceInitializeRect)
   at Infragistics.Win.UltraWinGrid.UltraGrid.OnPaint(PaintEventArgs pe)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
And the Index error:
System.IndexOutOfRangeException: Index was outside the bounds of the array.
   at System.Collections.Generic.Dictionary`2.FindEntry(TKey key)
   at System.Collections.Generic.Dictionary`2.TryGetValue(TKey key, TValue& value)
   at Infragistics.Shared.SparseArray.GetItemAtScrollIndex(Int32 scrollIndex, ICreateItemCallback createItemCallback)
   at Infragistics.Win.UltraWinGrid.ScrollCountManagerSparseArray.GetItemAtScrollIndex(Int32 scrollIndex, Boolean allocate)
   at Infragistics.Win.UltraWinGrid.RowsCollection.GetRowAtScrollIndex(Int32 scrollIndex, Boolean allocate)
   at Infragistics.Win.UltraWinGrid.RowsCollection.GetRowAtScrollIndex(Int32 scrollIndex)
   at Infragistics.Win.UltraWinGrid.UltraGridLayout.GetRowAtScrollPos(Int32 pos)
   at Infragistics.Win.UltraWinGrid.ViewStyleBase.CreateRowsList_FixedRowsFeature(VisibleRowFetchRowContext& context, VisibleRow parentVisibleRow, UltraGridRow firstSibling)
   at Infragistics.Win.UltraWinGrid.ViewStyleBase.RecreateRowList(RowScrollRegion rsr)
   at Infragistics.Win.UltraWinGrid.RowScrollRegionsCollection.AreScrollbarsVisible(ScrollbarVisibility assumeColScrollbarsVisible)
   at Infragistics.Win.UltraWinGrid.ColScrollRegion.ResetScrollInfo()
   at Infragistics.Win.UltraWinGrid.ColScrollRegion.RegenerateVisibleHeaders()
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.PositionScrollbar(Boolean resetScrollInfo)
   at Infragistics.Win.UltraWinGrid.ScrollRegionBase.SetOriginAndExtent(Int32 origin, Int32 extent)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.SetOriginAndExtent(Int32 origin, Int32 extent)
   at Infragistics.Win.UltraWinGrid.DataAreaUIElement.ResizeRowScrollRegions()
   at Infragistics.Win.UIElement.DrawHelper(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Boolean clipText, Boolean forceDrawAsFocused, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   at Infragistics.Win.UltraWinGrid.UltraGridUIElement.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   at Infragistics.Win.UltraControlBase.OnPaint(PaintEventArgs pe)
