325
UltraGrid Invalidate() flicker
I am working on a financial application that needs to handle real-time price updates. Prices changes are highlighted by setting the back colour to green or pink. There is a timer that fades back to the default back colour after a couple of seconds.
I am currently testing this functionality and have found that the grid flickers heavily when the data is updated and the grid needs to repaint. Currently I'm simulating 10,000 updates per second. I also have a timer that ticks every second to fade the changed price's cell back to it's defalt colour. At the end of each fade step I need to invalidate the grid.
These two operations cause the mouse to flicker unacceptably and also cause the  docked control I also have on the same Form to take several seconds to fully in a very jerky fashion now.
 Is there a way to improve performanc/smoothness?
Jay
  • 2070
    Hi Jay,
    What you can do is use BeginUpdate/EndUpdate methods of the UltraGrid to throttle how often it repaints, like 3-4 times a second. This way every cell update will not result in an invalidation or subsequent processing, but rather the entire grid will repaint set number of times a second. Also there are certain settings you can apply to speed up rendering. I've attached a test sample that throttles grid paint. It also sets some things in the InitializeLayout event handler to speed up grid painting.
    Hope this helps,
    Sandip
    WinGridPaintThrottling.zip
