650
UltraGridExcelExporter for List<T>
I have a List<MyClass> which is bound to a bindingsource and the grid to the datasource.
The grid's MaxBandDepth is set to 1 to only show MyClass values.
I have added the ExcelExporter to the form but when it goes through:
expExcelExporter.Export(ultraGrid1, Infragistics.Excel.WorkbookFormat.Excel97To2003);
Nothing happens.
Please help!
UPDATE: I just added a filename to it and looked in the directory and there it was! I thought it might open Excel or something.
  • 469350
    Verified Answer
    The method call you list here seems to do nothing because this overload of the Export method exports the grid to a WorkBook. Since you are not storing the Workbook in a variable, nothing happens to it.
    If you use an overload of the Export method that takes a FileNamem it will save the workbook to a file.
    If you want to open that file in Excel - assuming Excel or some other Excel file reader is installed on the the machine, you could call Process.Start(fileName).
