935
show VertScrollBar only if text not fit in cell
Hi
I am using
1) I am using the below to show vertical scroll in a cell but I dont want show vertical scroll bar if it  text fits in a cell.
e.Layout.Bands[0].Columns["column1"].VertScrollBar = true;
e.Layout.Bands[0].Override.RowSizing =
Please advise.
RowSizing.AutoFree;
  • 469350
    Suggested Answer
    I don't think there's any way to do this.
    It would be extremely difficult to determine if the text fits within the cell. You might be able to do this by getting the cell's EditorResolved and check getting the ideal size from the editor.
    But even if that works (and I'm not sure that it will), the VertScrollBar property is not available on the cell, only on the entire column.
    You should Submit a feature request to Infragistics
