785
Default context menu and cells with MaskInput set
We are experiencing an issue with cells having a input mask set on them. The default context menu does not show up when the cell is in edit mode and we right-click in it. The cell simply exit the edit mode.
This issue is happens if you have to following properties on the grid:
1. HeaderClickAction.SortMulti
2. CellClickAction.Edit
3. row selection type set to SelectType.Single
If row selection type is set to none, we do see the default context menu.
How can I make sure the menu will show up even if we have an input mask for the cell in edit mode?
Annie
We are using .NetAdvantage 2009 vol.1
