215
How to determine if grid column is required (allow or not allows null)
Is there a way to determine if an Ultragrid column allows or does not allow nulls. I want to change the header caption (like adding an * to caption and changing the text color) to indicate the column is required. My grids are usually connected to datatables from a dataset. I know there is an AllowNull property on the column in the datatable, but how do I determine this from the Ultragrid column?
