875
Parameter is not valid - Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter..ctor()
"Parameter is not valid.
at System.Drawing.Graphics.GetHdc() at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter..ctor() at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter..ctor(IContainer container) at MyGrid..ctor()"
For some reason, after a period of time, whenever one of my win forms loads, and there's a grid to be initialised, I get the above error. The error persists until the application is restarted. Has anybody else seen this? I am using 8.3.20083.2021. I'm sure I've seen somewhere that it may be down to the number of window handles it uses up, as there is a leak of sorts. I realise that I could upgrade to the latest version, but management will not allow this unless there is a very good reason as it envolves a mass roll out to thousands of user machines. Perhaps there is a hot fix.
If somebody could let me know in which version it was found and perhaps in which version is has been fixed?
Thanks for any help, Andrew
