I am getting the usually error message: Object reference not set to an instance of an object, when iam trying to export a UltraGridWin.datasource to a pdf using using a System.timer.timer, but when i run the code not using a thread everyting works fine. It also works fine when iam exporting to an excel file.
Iam using netadvantage 7.3
(excel)
Me
.expExcelExporter.Export(Me.grdReport, strPathName)
(pdf)
Me.expPdfExporter.UseFileBuffer = TrueDim bufferFileName As String = Path.Combine(strSavepath & "\", "ExportFileBuffer.tmp")Me.expPdfExporter.FileBuffer = bufferFileNameMe.expPdfExporter.Export(Me.grdReport, strPathName, UltraWinGrid.DocumentExport.GridExportFileFormat.PDF)
System.NullReferenceException was caught Message="Object reference not set to an instance of an object." Source="Infragistics2.Win.v7.3" StackTrace: at Infragistics.Win.UltraWinMaskedEdit.MaskInfo.IsMaskModeDefined(MaskMode mode) at Infragistics.Win.UltraWinMaskedEdit.MaskInfo..ctor(EditorWithMask maskEditor, EmbeddableEditorOwnerBase owner, Object ownerContext) at Infragistics.Win.EditorWithMask.DataValueToText(Object valueToConvert, EmbeddableEditorOwnerBase owner, Object ownerContext) at Infragistics.Win.EditorWithMask.GetSize(EditorSizeInfo& sizeInfo) at Infragistics.Win.DateTimeEditor.GetSize(EditorSizeInfo& sizeInfo) at Infragistics.Win.EmbeddableEditorBase.GetSize(EmbeddableEditorOwnerBase owner, Object ownerContext, Boolean valueOnly, Boolean full, Boolean borders, Int32 maxTextWidth, Int32 height) at Infragistics.Win.UltraWinGrid.UltraGridColumn.CalculateCellTextWidth(UltraGridRow row, Graphics gr, StringFormat stringFormat, Int32 maxColWidth) at Infragistics.Win.UltraWinGrid.UltraGridColumn.TraverseRowsCallback.Infragistics.Win.UltraWinGrid.RowsCollection.IRowCallback.ProcessRow(UltraGridRow row) at Infragistics.Win.UltraWinGrid.RowsCollection.InternalTraverseRowsHelper(UltraGridBand band, IRowCallback rowCallback, IRowsCollectionCallback rowsCollectionCallback, Boolean recursive, Boolean includeTemplateAddRows) at Infragistics.Win.UltraWinGrid.UltraGridColumn.CalculateMaxCellTextWidth(Int32 maxColWidth, RowsCollection rows, Int32 nRows, Int32 maxRowsCollections) at Infragistics.Win.UltraWinGrid.UltraGridColumn.PerformAutoResizeHelper(RowsCollection rows, Int32 nRows, Boolean applyWidth, Boolean includeHeader, Boolean includeCells, Int32 maxRowsCollections) at Infragistics.Win.UltraWinGrid.UltraGridColumn.PerformAutoResizeHelper(RowsCollection rows, Int32 nRows, Boolean applyWidth, Boolean includeHeader, Boolean includeCells) at Infragistics.Win.UltraWinGrid.UltraGridColumn.PerformAutoResize(PerformAutoSizeType autoSizeType, Boolean includeHeader) at Infragistics.Win.UltraWinGrid.UltraGridColumn.PerformAutoResize(PerformAutoSizeType autoSizeType) at Infragistics.Win.UltraWinGrid.DocumentExport.UltraGridDocumentExporter.PrepareLayoutBeforeBeginExport(UltraGridLayout exportLayout) at Infragistics.Win.UltraWinGrid.DocumentExport.UltraGridDocumentExporter.BeginExportInternal(UltraGridExporterHelper ultraGridExporterHelper, UltraGridLayout exportLayout, RowsCollection rows) at Infragistics.Win.UltraWinGrid.DocumentExport.UltraGridExporterHelper.Infragistics.Win.UltraWinGrid.IUltraGridExporter.BeginExport(UltraGridLayout exportLayout, RowsCollection rows) at Infragistics.Win.UltraWinGrid.UltraGrid.Export(IUltraGridExporter exporter) at Infragistics.Win.UltraWinGrid.DocumentExport.UltraGridDocumentExporter.Export(UltraGrid grid, ISection section) at Infragistics.Win.UltraWinGrid.DocumentExport.UltraGridDocumentExporter.Export(UltraGrid grid, Report report) at Infragistics.Win.UltraWinGrid.DocumentExport.UltraGridDocumentExporter.Export(UltraGrid grid, String fileName, GridExportFileFormat fileFormat) at TestProsjekt.frmDokumentExporter.GeneratePDFandSendEmails(Object source, ElapsedEventArgs e) in C:\utvikling\TestProsjekt\TestProsjekt\Form1.vb:line 113 InnerException:
You cannot do this using a separate thread. The DocumentExporter will attempt to access the grid and the data on the UI Thread and this will result in unmarshalled calls across the threads which is very dangerous and will almost certainly cause errors.
The only safe way to do this would be to create a new grid, and new data source, and a new DocumentExported all on the same thread and then do the export.
