I'm developing an application where the User can insert working shifts. I show the summary of the inserted shift using an UltraDayView and the problem is that I must specify the DayOfWeek before setting working hours.
If the User inserts a biweekly shift with different working hours beetween the 2 weeks, then i'm not able to properly create the summary as I have 2 different working hours for the same DayOfWeek.
So, how can I implement that?
Thanks a lot for any suggestion!
Stefano
