215
The font is boldly by degrees
hi~
I have a issue when I added a ultrachart in usercontrol.
I set usercontrol's backcolor to transparent. And I added background image to chart.
And I set BackgroundImageStyle property of chart to StretchedFit.
But the font is boldly by degrees. What should I do?
thanks~
  • 28496
    i was not able to reproduce this behavior by following the steps you described.  try changing the values of the SmoothingMode and/or TextRenderingHint properties, maybe that will help.  if it doesn't, could you provide a sample project for me to investigate the problem?
