475
UltraRadio button
Can anyone tell me how to set a Short cut for ultraradio button? I tried using & sign in front of the text but it did not work. I also set the UseMnemonic Property to true but it did not help...Any suggestions???
  • 469350
    Suggested Answer
    There's no UltraRadioButton control that I know of. I assume you are talking about UltraOptionSet.
    So I tested this out with the following code:
                this.ultraOptionSet1.UseMnemonics = true;
                this.ultraOptionSet1.Items.Clear();
                this.ultraOptionSet1.Items.Add("Apple", "&Apple");
                this.ultraOptionSet1.Items.Add("Banana", "&Banana");
                this.ultraOptionSet1.Items.Add("Cherry", "&Cherry");
    This seems to work fine for me... but the mnemonics do not display immediately when I run the application. They only display when I press the Alt key on my keyboard. This is default behavior in Windows Vista and I get the same behavior with any control, including the inbox button.
    So if you are running Vista, perhaps that's why you are not seeing the mnemonics.
