I am taking the section example in the documentation and trying to add a footer to it, the page number is not lining up with footer. What do I need to do to get things to line up correctly? I would like the footer to be lowered, not the page number raised:
public static void Run() { Report report = new Report(); // Create the main Section ISection section = report.AddSection(); section.PageMargins.All = 40; // CreateHeader(section); // Get a reference to the section's PageNumbering object. Infragistics.Documents.Report.Section.PageNumbering pn = section.PageNumbering; // Create a style for the page numbering font. pn.Style = new Infragistics.Documents.Report.Text.Style(Fonts.Arial, Infragistics.Documents.Graphics.Brushes.Black); // The Template property is the actual string that // shows the page numbering. Use the [Page #] place- // holder for the current page and the [TotalPages] // place-holder for the total amount of pages in // the entire document. pn.Template = "Page [Page #] of [TotalPages]"; // Setting SkipFirst to true does not place page // numbering on the first page of the section. This // is useful if the first page is a Title page. pn.SkipFirst = false; // The page numbering will be aligned with the // right side of the page. Valid values off the // Alignment enum include Left, Center, and Right. pn.Alignment.Horizontal = Infragistics.Documents.Report.Alignment.Right; // The page numbering will be located at the // bottom of the page. Valid values off the // Alignment enum include Top and Bottom. pn.Alignment.Vertical = Infragistics.Documents.Report.Alignment.Bottom; // The page numbering is at the extreme bottom // of the page, so we need to change the Y Offset // in order to bring it in line with the rest of // the page footer text. pn.OffsetY = -18; ISectionFooter footer = section.AddFooter(); footer.Height = 30; IText text = footer.AddText(0, -18); text.AddContent(string.Format("Date printed: {0}", DateTime.Now.ToString("dd-MM-yyyy"))); string reportName = GetPDFName(".pdf"); report.Publish(reportName, FileFormat.PDF); System.Diagnostics.Process.Start(reportName); }
pn.OffsetY = -18;
footer.Height = 30;
Mike,
Thank you for the reply. I am sorry, but I am not going to mark it as an answer, because it really isn't one. The more I work with this document reporting system, the more it looks like it is not a fully baked. It works for me and we already have it, so I will continue to use it, but is my impression correct that it is more of a work in progress then the core WinForms library?
Sam
Unfortunately, I don't have the time to get into that much detail. There's no way to automatically line it up. The PageNumber is independent of the other objects on the page - it basically draws right over them in a separate sort've layer. So you can turn off the Margins on the bottom to get your footer lower down on the page and then adjust the offset to raise the PageNumber up to line up with it. But I think that's the best you will be able to do.
I took the time to provide a complete working example in hopes that you or someone else could simply go in and add the few lines of code to make it look correctly. There are really only a few extra lines from an example I got from the Infragistics documentation.
If you want the page footer to be lower, you need to change the Margins. The Margins are what is making the footer appear so high on the page.
