95
Possible Grid OnPaint bug when using ControlContainerEditor
I think this maybe a bug but I'm hoping there is a way around it.
I have two monitors 1 (left) and 2 (right) and a grid with a cell containing a ControlContainerEditor.
I have a scenario where the grids location x,y is on screen 1. If the cell containing the ControlContainerEditor is expanded (either by resizing the column directly or by resizing the form with a fill docked grid and AutoFitStyle.ExtendLastColumn) and this expansion results in the new position of the right edge of that column falling on to screen 2 the following exception occurs.
System.ArgumentException: Parameter is not valid.
   at System.Drawing.Bitmap..ctor(Int32 width, Int32 height, PixelFormat format)
   at System.Windows.Forms.Control.DrawToBitmap(Bitmap bitmap, Rectangle targetBounds)
   at Infragistics.Win.ControlContainerEditor.GetRendererImage(Size imageSize, EmbeddableEditorOwnerBase owner, Object ownerContext, ControlContainerEmbeddableUIElement controlContainerEmbeddableUIElement)
   at Infragistics.Win.UltraWinEditors.ControlContainerEditorEditAreaUIElement.DrawForeground(UIElementDrawParams& drawParams)
   at Infragistics.Win.UIElement.DrawElement(UIElementDrawParams& defaultDrawParams)
   at Infragistics.Win.UIElement.DrawChildElements(UIElementDrawParams& drawParams)
   at Infragistics.Win.UIElement.DrawHelper(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Boolean clipText, Boolean forceDrawAsFocused, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.UIElement.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Boolean forceDrawAsFocused, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   at Infragistics.Win.UltraWinGrid.UltraGridUIElement.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   at Infragistics.Win.UltraControlBase.OnPaint(PaintEventArgs pe)
   at Infragistics.Win.UltraWinGrid.UltraGrid.OnPaint(PaintEventArgs pe)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
The problem also occurs in the ControlContainerEditor example project, I used the "Same Control" example. I did notice that this configuration wont let you resize the column outside the bounds of screen 1 but if you make it big enough first and then move the whole form so that ity is cross screens and try to resize it again you get the same exception.
Any ideas?
Andy.
