Hello
I have an Excel file which I load into an Infragistics.Excel.Workbook object. In this Excel file, I have a cell where I put a value, and another one which calculates something from the first one. In my code, I want to retrieve the resulting value from this second cell, but all I can get is the formula itself.How do I tell the Infragistics.Excel engine to give me the value, not the formula?ThanksGuy
Currently, there is no way to directly get the cached calculated value. Can you post the file with the problem and let me know which cell you are trying to access? I will see if there is a way to get the value.
Excel file i am working has linkage broken but excel still displays value. Is they any way can i retrieve display value of the cell rather than formula? BTW, i am using v10.1 dll's. Any help is greatly appreciated. I am validating an existing process so fixing formula is not an option.
In that case, I think I will need to see the source code related to populating the worksheet to be of any help. It is something you can post on this thread? If not, I will have a Developer Support engineer contact you to create a private case.
It shouldn't be my case, beacuse if it was, it would be irrelevant to put Recalculate() or not before looping my cell values. In my case, instead, if I execute Recalculate(), all formulas are calculated just once and all is running well, if I comment Recalculate(), it seems to calculate all formulas every time I ask for a cell value.
When you add in new formulas in your sample, are many of the other existing formulas dependant on that new formula (directly or indirectly). In other words, would the added formula require all other formulas to be recalculated?
