460
How can I Disable Right Click and shortcut keys in UltraTextBox
Im creating a gradebook program.
Some textbox should not accept numbers
what I did here is I've created a keypress event and handles the event if the user input other of type integer/number.
But then What if the user use the right click and paste characters that is not qualified to be a number?
So then I thought I should Disable the right click functionality of the textbox,
I thought disabling the right click for ultratextbox is the same for UltraExplorerBar(list view)
but I cant find the "showDefaultContextMenu" property in the UltraTextbox.
So how do can I do this?
any Help is greatly appreciated
  • 469350
    Suggested Answer
    The default context menu you see when you right-click on UltraTextEditor actually comes from the inbox TextBox control which is overlaying the control.
    The only way to remove this is to create a context menu with no items on it and assign it to the UltraTextEditor.
    Note that this will not disable the keyboard shortcuts for cut, copy, and paste. You will still need to use the Key events for that.
