I have two UltraGrids.
Both UltraGrid can pass rows from one grid to another using Drag & Drop. I need to check that the row doesn't already exist on the destination grid.
This is that I have done:
private void uGrid2_DragEnter(object sender, DragEventArgs e) { if (e.Data.GetDataPresent(typeof(UltraGridRow))) { UltraGridRow row = e.Data.GetData(typeof(UltraGridRow)) as UltraGridRow; if (!uGrid2.Rows.Contains(row)) { e.Effect = DragDropEffects.Copy; } } }
1) Drag a row from the grid1 to GRID2 2) Repeat the same step, with the same row The condition always returns false.
always is false...
Why?
OK, thanks :)
The Contains method doesn't look at the data in the row. It just looks at the actual instance of the object you pass in. So a row in the first grid will never exist in the second grid, because it will always be a different instance.
So this will work if you try to drag a row from grid1 into grid1. But it will not work for dragging a row to a different grid.
You will probably need to compare the data in the row, perhaps using some key value.
