20
Problem with Infragistics toolbox in winforms
Hi  we have Visual Studio 2008 9.0 on Windows 7 64bit.  We  install  NetAdvantage for ASP.NET 2008 Volume 2 CLR 2.0 but  in don't see Infragistics controls in toolbox. So we try use Infragistics2.ToolboxUtility util, but it finished with this error:
Than we try reg dte.olb, but in Windows 7 is not in folder :
C:\Program Files\Common Files\Microsoft Shared\MSEnv\DTE.OLB
We try use Infragistics2.ToolboxUtility with many combination of parameters but, we don't still see
Infragistics controls in toolbox. Any advice?
  • 681
    That version of the utility needs at least the version number of the product you want to install tools for.  So in this case it'd be "8.2".  The shortcut that is created in the start menu calls the utility with the options "/v 8.2" which just runs the utility with verbose logging.
