We have some odd tool tip behaviour, it displays double and displays the last node in the list.
A shout out goes to our tester Adrian for being so persistant :)
Hi Sean,
I ran your sample and everything seems to be working fine for me. Is there anything I need to do other than run it and mouse over some of the nodes that are cut off?
Perhaps this is already fixed. Are you using the latest service release?If not, you should get it.
EDIT: Oops, just ignore that. I played around with it a little more and I got it to happen by mousing over the last node and then moving up. I'm going to forward this thread over to Infragistics Developer Support so they can check it out and get it fixed.
So I figured it out when you have mixed nodes formattedlink and regular along with style = vista causes the issue.
That's odd. I've never seen that before. Can you reproduce this in a small sample project so we can take a look?
