Hello Everyone,
I would like to have a caption for one column in a grid to display as two lines, since the data needs a lot less room than the column discription. I have look but can't find what I need to set to make this happen.
Is this possible?
Thanks for any help.
Kris
Hi Kris,
It depends on whether or not you are using RowLayouts. In a RowLayout, you can use the Designer to size the column header or you would have to set the PreferredLabelSize.
In normal mode, you just set ColHeaderLines.
