I have a command button in a UltraGroupBox and I highlight (click on) it and try to move it and the position of the control is set to -143, -357
If I exit out of the IDE and come back in. I am able to move the controls that were added. As I add controls and move them... the new control's position are set to negative numbers.
Requested support for this issue: Case Number: CAS-41770-E76VTL
I'm on 9.2.20092.2058
I will post a bug report.
I thought you ment at run time. That happened to me once. I just changed the x and y properties in the properties window and it was fine. Make sure you have the latest hotfix.
In Visual Studio 2008...when I have the designer up (form), I go to properties and find the control in the list and see the negative X, Y values.
How do you check the button position?
