165
need small help in Ultragrid in vb6
i m new to ultragrid n tried a lot..but not succeeded Plz help very urgent......
1) how to insert new row when click on add button...if any previous row is there has to clea out and add only 1 new row..
how to delete row on click of delete button (i tried using deleteselectrow..but need to select row first..what if only 1 row is present then need to directly delete present row)
2)
I am using VB6
with MS Access as backend database. The recordset is bounded to
database through� Infragistics ultragrid. (Set ultraGrid.DataSource = rs)
I have 3 columns in Infragistics ultragrid & 3 Textboxes on form.
Now, when I move through the records in ultraGrid the exact data in the cells should appear in the related textboxes.
in msflex i think we do with
Text1.Text = MSHFlexGrid1.TextMatrix(MSHFlexGrid1.Row,1)
How to get this job done? in ultragrid
plz help..sm1 atleast
