395
Problem with UltraChart item click
I have a problem with ultrachart (9.2 hotfix 2042)...
I need to get right click event on item in ultrachart (GanttChart Type) but with ChartDataClicked event I can't understand which mouse button has been clicked.
My workaroud idea was:
- handle MouseClick event
- in the handler save a boolean field rightClick = true
- in the ChartDataClicked handler check rightClick field
but the problem is that MouseClick event is not fired when you click on items, but only when you click in portion of chart with no item...
Any idea to solve that ?
I also say that I handle chartItemOver-out to show my custom tooltip manager... could it be the problem ?
Thx in advance
  • 395
    posted in reply to Teodor Taushanov
    It was a stupid question after all :)
    I thought ChartDataClicked event raised on mouse button release, so I didn't check Control.MouseButtons...
    My fault, thanks a lot for the help.
    P.S.
    I got a problem posted here --> LINK
    but with no response... It's a ribbon-ultrachart issue so I think that concerns also to this forum section, could you give a look at it ?
    Thank a lot again Teodor
  • 17605
    You can find which mouse button is clicked with Control.MouseButtons. For example:
    if (Control.MouseButtons == MouseButtons.Right)
  • 395
    Ok, I did it through InteractionTool, as shown in the code below.
    Do you think is the best way, or is there one better, less stupid, more efficient ... solution ??
    Overridden Interaction Tool Class:
    public class EventArgs<T> : EventArgs
    public T Value
    get;
    private set;
    public EventArgs(T value)
    this.Value = value;
    public class ItemClickInteractionTool : InteractionTool
    #region Public Events
    public event EventHandler<EventArgs<Primitive>> ChartDataPointClicked;
    #endregion
    #region Private Fields
    MouseButtons mouseButtonFilter;
    #endregion
    #region CTOR
    public ItemClickInteractionTool(UltraChart chart, MouseButtons buttonFilter)
    : base(chart)
    mouseButtonFilter = buttonFilter;
    #endregion
    #region Overrides
    public override bool CanStart()
    if (this.LastInput.MouseEventArgs != null &&
    this.LastInput.MouseEventArgs.Button == this.mouseButtonFilter)
    var primitive = this.HitTest(this.LastInput.ViewPoint);
    if (primitive != null && primitive.DataPoint != null)
    return true;
    return false;
    public override void Start()
    this.OnChartDataPointClicked(primitive);
    #endregion
    #region Private Methods
    private void OnChartDataPointClicked(Primitive dataPoint)
    if (this.ChartDataPointClicked != null)
    this.ChartDataPointClicked(this, new EventArgs<Primitive>(dataPoint));
    #endregion
    Interaction Tool Initialization:
    itemRightClickInteractionTool =
    new ItemClickInteractionTool(this.ultraChart, MouseButtons.Right);
    itemRightClickInteractionTool.ChartDataPointClicked +=
    new EventHandler<EventArgs<Primitive>>(
    itemRightClickInteractionTool_ChartDataPointClicked);
    ultraChart.AddMouseDownTool(itemRightClickInteractionTool);
  • 395
    Any suggestion ?
